Extreme trailer oil bath bearing hubs
  • Joshf
    • Aug 2012
    • 23
    • Salt Lake City, UT
    • 2008 Super Air 220
    Just towed the boat for the first time this season, is this a bad sign?
  • pSchwade
    • May 2012
    • 127
    • Reno
    • 07' 220 SANTE
    Is that grease or oil? I thought the oil filled hubs were supposed to be sealed.
    • ski4evr
      • May 2010
      • 613
      • Bowling Green, KY
      • 2005 SV 211
      lots of bad press on oil filled hubs and boat trailers. UFP gave me new bearing buddies for free just the get them off my trailer. apparently, the dunk in the lake after getting hot while towing can blow the seals and let water in or oil out.
      2005 SV-211
      • Nautiquehunter
        • Jun 2008
        • 2080
        I lost my second cap on my Boatmate with the vault system. It looks like they get hot build pressure and push the outer cap off. Throws grease everywhere.
        • Joshf
          • Aug 2012
          • 23
          Oil, you can see the spot that i wiped clean with my finger. I thought they were supposed to be sealed as well
          Sent from my SM-T237P using Tapatalk
          • enzo thecat
            • Aug 2010
            • 221
            • Lake Wawasee among other places
            • 2016 G21
            Since boat trailers dont get used much, the seals the seals dry out. The boats are so heavy that the spindle can overheat to the point that it seizes to the axle. Ask me how I know (just last season). $1700 repair when that happens. Hopefully you just have to replace your seals. That will be inexpensive.
            2016 G21 SupeAir.
            • nohlan_4
              • Jan 2016
              • 413
              • Canada
              • 2013 G23 450
              Yup looks like your seal went. I lost one off my trailer 100 miles after picking my boat up, I had no choice but to trailer it the rest of the way (1000 miles) before I could get a replacement. I didn't have any damage to the axle bearings or problem getting hot but I also have a tri axle trailer which I feel makes a huge difference on the heavy boats, I have a G23.
              • KamiKaze
                • May 2020
                • 1
                • Las Vegas
                • Malibu Wakesetter 247
                I know that post was quite a while back but, if it's not a rubber seal, something my mechanic told me to do with the oil bath bearing protector, is to put a bead of gasket sealer on before installing. I've never had a leak.
                • shag
                  • 2217
                  Cheap grease (even good grease) can almost liquefy when it gets hot.
