SAN 230 Tongue Height
  • GemCitySurf
    • Oct 2016
    • 104
    • Cincinnati, OH
    • 2017 SANTE 230
    I have a 2017 SAN 230 with a Boatmate Trailer. I called Boatmate and asked if there was a preferred tongue height to ensure proper tongue weight. They said 18"-21". Has anyone measured?
  • Quinner
    • 2246
    • Correct Crafts
    Ideally you would want to measure your trailer when perfectly level and measure how much your vehicle sags when boat is hooked up, add sag to the level height and round up.
    • GemCitySurf
      • Oct 2016
      • 104
      • Cincinnati, OH
      • 2017 SANTE 230
      I would think you would want the front to be a tad low, no? Since the major weight of the boat is in the back?
      • Quinner
        • 2246
        • Correct Crafts
        Level is what you want, if you are between drops go high since the tow vehicle likely will never sit higher rather lower if loads increase. The trailer should be designed to carry the weight correctly, 10% tongue weight max, so with a VDrive boat axles will be further back vs a direct drive where axles will usually be directly below motor.
        • 4th ski-doo
          • Apr 2013
          • 307
          • Wilmington
          • 2013 SANTE210 2011 Sport200V 1994 Bimini Skier 190 1986 Master Craft Pro Star 190
          Level, that's the trick! Any trailer needs to be level, everything works better that eay
          2013 SANTE 210
          2011 Sport 200 V
          1994 Bimini Skier Pro 190
