Can I pull my trailer with no brake hardware
  • chefred112
    • Jul 2016
    • 98
    • Tracy, CA
    • 1995 Super Sport
    Hi All,
    I had a bearing go bad on my dhm tandem trailer (port/left side)...I was able to replace the bearing hardware...during the process, I removed all the brake stuff as some of it went bad when the bearing blew. I need to move the boat to my home which is 4 miles away and finish the work there. If I do not reconnect the brake line at the tongue, would it be ok to tow?
    thanks...fred
  • charlesml3
    • Jan 2008
    • 2454
    • Lake Gaston, NC
    • 2022 G23
    Originally posted by chefred112 View Post
    Hi All,
    thanks...fred
    I don't see why not. A 95 Super Sport isn't all that heavy and you're not going far. Just be careful and don't get into a sudden brake situation.
    -Charles
    • chefred112
      • Jul 2016
      • 98
      • Tracy, CA
      • 1995 Super Sport
      thanks Charles, I was thinking same thing...I pull with an Expedition and the boat does feel light behind it but like you said, I'll start coasting/slowing down earlier and brake earlier...
      • swatguy
        • 1631
        • Midwest/ Northern IL
        • 2008 SANTE 210
        Brakes are a luxury not a necessity on a 21ft boat. Tow away.
        this is assuming your brake line and master cylinder are empty. Just make sure you lock out the tongue so the cylinder doesn't compress.
        • chefred112
          • Jul 2016
          • 98
          • Tracy, CA
          • 1995 Super Sport
          Thanks swatguy, i got home with no issue, i didn't connect the brake fluiid cable... question, how would i lock out.the tongue?
          Sent from my SAMSUNG-SM-G935A using PLT Nautique mobile app
