Keep loosing bearing bras on downhill towing
  • wakejunky
    • 679
    • Ca
    • 2003 SAN
    Once a year we do a long tow trip that requires a 3200 foot pass, on the downhill, the brakes will heat up the grease in the bearing buddies enough to force the grease to start to move and I loose both bearing buddies and grease makes a disgusting mess on the wheels.
    Granted, it's good to have plenty of grease in the bearings but, is there a way to keep the bearing buddy bras attached?
  • t.franscioni
    • Jun 2014
    • 715
    • United States
    • 2002 SANTE
    Does your trailer have a manual lockout for the brakes to prevent them from engaging? Sometimes on trailers there is a lever you can throw to prevent the tongue from compressing. My DHM trailer has it and I use it to turn off the brakes on long steep down hill grades because my truck is big enough to not need braking assistance from the trailer anyway.
    • Outdoorjp
      • Jul 2016
      • 178
      • Carlsbad
      • 2011 SAN team 210
      Higher temp greese?
      • kmarine
        • Jun 2017
        • 109
        • chicago
        • boss gt40
        I never had any luck with them. As soon as the plastic heats up they come loose. When the get old they harden and fall off. I remove them on long trips and replace when I get home. Spray degreaser on the bearing buddy before installation may help You may need some to clean the grease off anyway when you get home.
        • a0128
          • Jan 2014
          • 423
          • Lake Oswego, OR US
          • 1999 Pro Air Nautique
          Originally posted by wakejunky View Post
          . . . is there a way to keep the bearing buddy bras attached?
          Maybe a jubliee clip . . . ?
          • wakejunky
            • 679
            • Ca
            • 2003 SAN
            Has anybody tried to convert their grease hubs to oil bath? Just looking at this product.
            http://www.kodiaktrailerbrakes.com/K...bs_p_1152.html
