Stainless Retractable Transom Tie Downs by Boat Buckle
  • LikensItALot
    • Apr 2015
    • 73
    • Cape Girardeau, MO
    • 2017 Nautique G23 2015 Nautique G25 Mastercraft X-45 Mastercraft Pr
    Just installed the Boat Buck Retractable Stainless Transom Tie Downs on my BoatMate Trailer.. Clean Look and easy to install... Nice piece of mind to have. If anyone is interested in a set the part number is F14256
    LikensItALot
  • shag
    • 2217
    I was thinking about getting them... How much?
    • LikensItALot
      • Apr 2015
      • 73
      The Stainless are $133.29 I did buy a install kit as well which was $13. I overall did not need the kit except the boats from it that attached the Boat Buckle to the trailer where way nicer then the bolts that came with the Kit.
      LikensItALot
      • srock
        • Oct 2008
        • 1066
        $40 for 2" non-stainless at walmart. I figured they will only be exposed when I trailer the boat and the strap is likely to wear first so I will chuck them and replace.
        • wakejunky
          • 679
          • Ca
          • 2003 SAN
          I've had a pair of non-stainless steel for over 14 years, they have not rusted out nor have the straps worn out. The only problem I've had then them was that one of the return springs broke so, I had to get a replacement.
