Lubing of F2 jack
  • XBIGPUN66
    • Oct 2012
    • 456
    • WI
    Lubing of F2 jack
    Has anyone performed the tsb for the Fulton F2 trailer jack where you drill a 3/8 hole in the casing and squirt grease inside to lube the acme screw? Just wondering if there are any tips you could share?
    Sent from my SAMSUNG-SM-G930A using Tapatalk
    Ian S
  • swatguy
    • 1631
    • Midwest/ Northern IL
    • 2008 SANTE 210
    Funny you post this. I was just about to lube mine up as it's starting to stick. Tried using the Zerk fitting but it pretty much was useless . Was gonna just rub grease all over the shaft , but that idea you metion above may work too. Can you eleaborate on the TSB
    • nyryan2001
      • Mar 2013
      • 1993
      • Lake Anna
      I've had 3 F2s fail. Junk.
      Went to a 5k rated stainless fixed drop leg. Never looking back.
      2019 G23 450
      2014 G23 550
      2013 G23 450
      2011 Malibu Wakesetter 247
      2007 Yamaha AR210
      • XBIGPUN66
        • Oct 2012
        • 456
        • WI
        I called Fulton and the e-mailed me a pdf which described how to lube the jack. If you have a vent hole you extend it all the way and put grease in the vent hole. If you don't have the vent hole you are supposed to drill a hole 1" below the gear housing.
        Ian S
        • XBIGPUN66
          • Oct 2012
          • 456
          • WI
          mine does not have a zerk fitting
          Ian S
          • ski4evr
            • May 2010
            • 613
            • Bowling Green, KY
            • 2005 SV 211
            Can you share the pdf with the rest of us
            2005 SV-211
            • XBIGPUN66
              • Oct 2012
              • 456
              • WI
              Email me. I will send it.
              Ian S
              • XBIGPUN66
                • Oct 2012
                • 456
                • WI
                I drilled the hole and lubed the jack today. I seems to be better now.
                Ian S
                • blueroom
                  • Mar 2017
                  • 623
                  • Northwest
                  • G23
                  The wheel surprisingly broke off of ours the other day - a good reminder to keep hands and feet clear of the tongue to avoid injury. Boatmate was awesome to deal with, and we had a replacement shortly. They said it is warrantied for life! Love working with companies with such great customer service!
                  Click image for larger version  Name:	IMG_1975.JPG Views:	1 Size:	75.0 KB ID:	534304
                  • ski4evr
                    • May 2010
                    • 613
                    • Bowling Green, KY
                    • 2005 SV 211
                    f2 lube F3834.pdf
                    2005 SV-211
