I see a lot of dual axle Boatmate G23 trailers with 18" wheels, and had wondered why my fully loaded trailer was ordered with 15" wheels. I think I know now.
I was on Boatmates page and saw something interesting. If you get the dual axle G23 trailer with 18”" wheels it is only rated for a capacity of 6900 pounds - the 15” wheel XL version has a capacity of 8300 pounds. With the G weighing in at 5900 dry, you add 500 pounds or so for fuel and such, it only leaves you 500 pounds for gear and everything else. It could be very easy to overload the trailer, especially if you add any additional weight, have a bunch of gear, etc. Even the 18”" wheel triple axle trailer is only rated at 8200 pounds (100 less than the double XL with 15’s), which I guess is why you see some triples out there. I always figured was overkill but now understand. If you are in an accident, no matter who is at fault, an overloaded trailer could be a liability.
http://boatmatetrailers.com/models_nautique.php
(XL) - We are now offering an XL or Extra Load rated trailer for the G23. XL models can only be ordered in the 15" wheel setup and recommended for those customers that may travel long distances or with a heavy load of gear on board. 18" Wheel options can't be rated at 10,000# GVWR unless ordered as a Triple-Axle Setup.
Thought it was interesting.
