Properly rated hitch ball and mount recommendation?
  • Team230
    • Oct 2015
    • 251
    • Cincinnati, OH
    • 2008 Super Air 230 TE
    I want to replace my ball and mount on my hitch with a new one. I'll be pulling a G23 and I don't need a drop down.
    Any suggestions for a good place or model?
  • Green
    • Feb 2018
    • 87
    • KS
    • 18-G23
    Very nice solid hitch that does it all. Buy a lock for it!!
    https://www.amazon.com/TS10048B-Magn...=A5GMD68O5WF03
    • surroundsound64
      • Jul 2005
      • 2147
      • Longview, TX
      • 2018 230 1981 Ski Nautique
      X2 for B&W
      2018 SAN 230
      1981 Ski Nautique
      Sold - 2011 Sport 200V
      Sold - 2000 SAN
      • neirbot
        • Jul 2015
        • 94
        • DFW
        • 2016 230
        Or this one for almost half the price. But you're not looking for a drop mount, so you could get something simpler and less expensive than either of these.
        CURT 45900 Adjustable Channel Mount https://www.amazon.com/dp/B004SMGAJ6..._H9J0AbF3VNKPP
        Sent from my Pixel 2 using Tapatalk
        • Infinity
          • Sep 2017
          • 730
          • Lake Norman - Denver, NC
          • 2014 SV244 w/ ZR409
          I did not need a drop down either. I just went to tractor supply....found a regular ball mount that either curved up slightly or down slightly (actually wanted mine to go up about an inch since I pull with 1500 truck and that is what it takes to ride level since I have 19" rims on my trailer), it was solid piece with no welds and rated for 16k lbs. Think it was like $30. Then I bought a ball rated for 12k lbs. I only use this one for pulling boat, I have a tri for other trailers and it works out good cause I just ordered rock guard flaps that i will attach to that specific mount (so I can remove entire set-up when not towing boat). Decided I better add rock guards since I just switched from the factory tires, to BF Goodrich KO2 tires. Because of AT tread pattern, they will pick up gravel and other debris a lot easier and kick it up and I want to protect my black hull. Another bonus is the tires are 10ply, so lot more resistant to punctures, handle more weight, can run with higher psi which will make them last longer and better "grab" on boat ramps.
          • Wake.BC
            • Jan 2016
            • 423
            • BC, Canada
            I’ve got a 3 ball tri mounted with a 2 1/2” diameter which is so much better than the sleeve on the HD trucks. Always have the three sizes of hitches and they’re rated for over 10k
            • Cpan13
              • Jan 2016
              • 339
              • Canada
              • Current - 2021 G23 … Previous - 2020 Supra SL450, 2015 G23, 2014 G21, 2012 Epic 21V
              Where did you get a 3 ball with that rating? All of the ones I’ve seen have been 3-5k.
              • Wake.BC
                • Jan 2016
                • 423
                • BC, Canada
                It’s so handy to have all three sizes ready to go. Seems silly that boatmate doesn’t go to a the 2 5/16”
                https://www.hitchweb.com/product/88/...rated-to-balls
                • Andy1972
                  • Oct 2004
                  • 128
                  I bought the Curt adjustable, awesome. Probably the last one I’ll ever buy.
