Trailer brakes
  • Gbracer
    • Dec 2018
    • 83
    • Langley BC
    • 2015 G25 550
    Trailer brakes
    Tried backing up the other day up a hill with the boat and the hydraulic trailer brakes were doing thier job, to the point I could not move the trailer backwards anymore, is there a way to lock the brakes so they do not come on when manouvering backwards up hills, the more you push the more the brakes come on. trailer is a 2018 boat mate.
  • charlesml3
    • Jan 2008
    • 2454
    • Lake Gaston, NC
    • 2022 G23
    Yes. When you're backing up a hill the surge brakes lean on the tongue and engage. That's why they're locking on you.
    Up on the tongue somewhere there's a pin that you can insert. You'll have to find it as it varies by trailer manufacturer. With this pin inserted the brakes will not engage. Keep in mind, that you do NOT want to tow with this pin in-place. It's only for this situation.
    This was the best I could find. Not sure if it applies to your trailer or not: https://www.boatmateparts.com/produc...ls.php?itmId=7
    • Tom_H
      • Jan 2014
      • 244
      • Minnesota
      I'm assuming disc brakes on a 2018 trailer as drums should back up ok, and I'd also assume that you should have a reverse lock-out solenoid on the surge coupler. If you do have a solenoid, either the solenoid has failed, or you're not getting power to it to disengage the brakes in reverse. For the solenoid to work it needs power off the tow vehicle's reverse lights. If you only have a flat-4 connector wired up, you'll never get the solenoid to engage, as it's not keyed into the reverse lights. You need to power off a 5 or 7-pin connector to get the reverse lights in the mix. So if you have a solenoid, check that you're getting power to it (and replace it if not), otherwise, a mechanical lock-out like Charles posted will be needed. Many people also like this magnetic one https://www.amazon.com/Noa-Store-Sur...a-574196848732. I've done the same with an appropriately sized C-clamp in a pinch.
      • Gbracer
        • Dec 2018
        • 83
        • Langley BC
        • 2015 G25 550
        I have a 7 pin plug but on my truck side they may not be wired in that lockout device should also work but i like the solonoid idea better, thanks for the info..
        • mikenbike211
          • Sep 2016
          • 447
          • New York
          • 2021 G21 2019 GS22 2017 GS20 2008 SV211 1990 Sport Nautique
          Make sure your 7 round connectors other end has a 5 pin flat (4 “exposed” pins plus one shrouded in rubber). 4 and 5 pin connectors are different and are often confused. Your trailer has the solenoid mentioned above and is either not getting the signal from the vehicle (“trailer brake”) fuse is blown, it is faulty, or you have the wrong connector installed.
          • Gbracer
            • Dec 2018
            • 83
            • Langley BC
            • 2015 G25 550
            I found out yesterday that Mt trailer is equiped witht the lock out solonoid I moved the boat yesterday with the truck and plugged in the light cord wala!! the lock out worked, I think last time I moved the boat I did not plug the cord in for a 50' move lol, I felt like a twit.
            • Pilotanderson
              • May 2018
              • 5
              • Dadeville, AL
              • 2005 Nautique 206
              Yeah, been there and done that also!
