Anyone have a decent amount of miles of tower down no cover towing on a 2019 G? Any issues? Is it as good and easy as it looks?
Yep, towed mine 300 miles (round trip) for a lake trip last season (I had one of the first 19s). No issues at all. Locked the Bimini and window and it was great.
Was nice not worrying about overpasses and gas station clearance. Shoot, if I was a pro I coulda gone thru McDonald’s drive thru with that puppy!
Follow up:
picked up the G yesterday and towed 300+ miles with the tower down.... it’s awesome.
1. If you have to tow any lengthy distances, absolutely tow with the tower down. Takes less than a minute to lower the tower and lock the Bimini in the low stowed configuration, and maybe a minute to return to regular tower up configuration. Very slick, quick and easy to do. Releasing the Bimini from the the low position: push DOWN on the Bimini to release the shock pressure.... not up. It’s counterintuitive.
2. No issues whatsoever in down configuration. Tower stops at the bottom, lock the Bimini down. Nothing is touching or rubbing to damage...you’re ready to tow.
3. You save gas with less wind drag. With my old Gs 6-7.5Mpgs at 65-73MPH. Last night I averaged 8.3mpgs on cheapie gas. With Shell it’d have been close to 9mpg.
4. Lower center of gravity = less lateral slop side to side over rough highways, construction seams and asphalt transitions. Less wobbly.
5. Less bugs, dirt and road grime.
6. Less wind beat down on your Bimini fabric.... which WILL rip and fray over time with 70mph winds.
all goodness guys, highly recommended.
also... the standard cover can be used tower up or in tower down config if you’re brave enough to try that towing.
1 Photo2019 G23 450
2014 G23 550
2013 G23 450
2011 Malibu Wakesetter 247
2007 Yamaha AR210
A d m i n i s t r a t o r
- Mar 2002
- 16517
- Lake Norman
- Mooresville, NC
Originally posted by nyryan2001 View Postalso... the standard cover can be used tower up or in tower down config if you’re brave enough to try that towing.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
For the tower up config... It has a very slick improved HangTyte type thing designed into it that loops onto the tower tow point... and pulls a rope sewn into the cover from bow to stern tight to prevent water pooling. I like it. Has 2 poles to assist.
In tower down config the tower holes close tight... I’m assume it relies on the folded tower taking up a lot of the slack to prevent water pooling... and the 2 poles
2019 G23 450
2014 G23 550
2013 G23 450
2007 Yamaha AR210
Originally posted by NautiqueJeff View Post
Interested to see the tower-up style cover on with the tower down. I only have a tower-down cover this year, so I don't have any experience with the other cover.2019 SAN G23 | 2016 SAN G23 | 2013 Wakesetter 23 LSV | 2008 Wakesetter 23 LSV | 2003 Wakesetter 23 LSV | 2000 Wakesetter VLX | 1998 Sanger V210 | 1994 Magic Sceptor 28 | 1985 Cole TR2 | Too many PWC to count!
