Originally posted by ST3
View Post
Originally posted by cwglee View Post
While i get the point of the test I think that, like many other theories, this would look far different with the weight over the axle (like a boats weight is distributed over the axle(s) of a trailer).
I think this topic is seriously lacking in information when it comes to boats. There's a lot of opinions and concepts taken from general trailering guidelines, but not much information specific to boat trailering.
I'd note I have a tandem axle 14k flat bed (20 ft.); a tandem axle 14k dump trailer (10 ft); a tandem axle 7k flat bed (16 ft.); a 10k TT (36 ft.) and have tested towing these trailers with different loads and measured tongue weights to see where each likes to tow. The longer the trailer the more susceptible to wig wag the trailer is, but they all start towing poorly with the tongue weight less than about 7-8%. The TT is almost untowable at less than 7% and likes to tow with about 12-13%. Even the short dump tailer has worse towing characteristics when the dirt is loaded such that there is not enough tongue weight but you can get away with less than the TT.
Boats are not as easy to test different tongue weights because it is not as easy to adjust the load. But I would need to see some evidence that boats somehow tow better with less tongue weight than other types of loads or that they are less prone to wig wag with say less than 7% tongue weight. I can see a trip axle trailer needing less tongue weight if the trailer is shorter and the load is lighter, but I will remain skeptical without seeing some evidence that 10% is not ideal or that they somehow tow better with say 5% on the tongue.
Originally posted by jjackkrash View Post
It would be good to add boat-specific trailering info if you have any to add.
The magazines articles will typically hit on the basics, overall weight, axle ability, tires, ratings on the various pieces of equipment from receiver hitch to hitch ball etc. All while sneaking in a pitch for whatever vehicle brand they are marketing in this printing. I haven't encountered anything discussing a WDH on a boat trailer, its a topic lacking in defintive facts.
As of right now I tend to agree that just the mechanics of a swing away trailer tongue with hydraulic brakes make it difficult to see how it would work well, but just my opinion having never tried one.
To answer the OP’s original question, trailering will be very different. A G23 doesn’t handle well at slow speeds compared to its 23’ peers. A 20’ Mastercraft would run rings around it. You’ll get used to it though.
As far as these tow questions, read your manual. Trust your manual. If you’re upgrading trucks to tow more, read that manual. It’ll be online somewhere.
Originally posted by cwglee View PostI haven't encountered anything discussing a WDH on a boat trailer, its a topic lacking in defintive facts.
I tow our GS24 every time to the lake and launch. 2017 Raptor, With no issues. Even took it to Lake Travis 4 hours away. I honestly prefer launching and bringing the boat back to my house to wipe down and prep for the next trip. The docks here on a lake Ray Hubbard suck and spiders are everywhere. So more peace of mind for me.
Originally posted by jjackkrash View PostWith a conventional/bumper pull hitch, the carry weight on the hitch can move significant weight off the steer axle and can change the way the truck breaks and handles because the hitch is acting as a lever (because it is substantially behind the drive axle). This is unlike a fifth wheel or gooseneck hitch which puts the carry weight directly on the drive axle. The front tires can have less friction and less connection with the road when the conventional hitch is acting like a lever with too much carry weight. The purpose of a WDH is to transfer some of the carry weight back through the truck frame to the steer axle and also back to the trailer axles to counteract the lever created by the conventional hitch. The reason many half tons require a WDH after 5000 lbs. on a conventional hitch (but not a fifth wheel hitch) is because they assume the hitch will be carrying at least 10 percent of that weight on the lever (otherwise the trailer is overly susceptible to sway and wig wag) and the truck is designed to have x amount of weight on the steer axle. Assuming that the "brakes" are not impacted by too much carry weight is a mistake, bacause it is not really the breaks so much as the traction created by the rubber and the weight on the steer axle that is impacted by carry weight. Also, for point of reference, a WDH does not increase a truck's payload capacity and whatever weight is carried on the combination of both axles counts against payload (although some tongue weight is distributed back to the trailer axle with a WDH). And while air bags can help with sag, the bags do not transfer weight back to the steer axle or solve the all the problems created by the lever that is the conventional hitch.
Sent from my iPhone using Tapatalk Pro
So, I looked up the details on when a WDH is needed. A bit confusing, but based on what I read, you a 3/4 ton truck would not dramatically change the need for a WDH with Nautique G. Has anyone measured their tongue weight? For example, a F150 well equipped, should be ok with 500 to 750 pounds of tongue weight, a f250 would extend that to 600 to 900 lbs. but there are lots of things here that don’t completely add up with the details listed.
I think I have a better appreciation for the weigh safe hitches.
Originally posted by Mahnal View PostSo, I looked up the details on when a WDH is needed. A bit confusing, but based on what I read, you a 3/4 ton truck would not dramatically change the need for a WDH with Nautique G. Has anyone measured their tongue weight? For example, a F150 well equipped, should be ok with 500 to 750 pounds of tongue weight, a f250 would extend that to 600 to 900 lbs. but there are lots of things here that don�t completely add up with the details listed.
Sent from my SM-G965U using Tapatalk
Hey all,
I just wanted to give an update with my experience towing my g23 now for a month with my 1500 Ram. I will say its not ideal and much different then towing my old nxt 20 but for my purposes it works fine. I did tow it 2 hours away on mostly flat freeway and didn't have any trouble with sway or braking. I think if I lived around mountains or did lots of towing I would recommend a bigger truck.
Also, for anyone searching, I started this thread with questions about getting the boat on the trailer. This has been super easy once I taught my wife to drive it on the trailer.
Curious if anyone has experience with larger SUV? We have a 2019 Land Cruiser with a tow rating of 8100lbs and was hoping to tow from Lake Austin to Lake Travis (just a few miles) with occasional trip to the dealer (20ish miles). I have experience towing our GS20 with a smaller SUV (lexus GX) and was not an issue.
Originally posted by stuckinaustinag View PostCurious if anyone has experience with larger SUV? We have a 2019 Land Cruiser with a tow rating of 8100lbs and was hoping to tow from Lake Austin to Lake Travis (just a few miles) with occasional trip to the dealer (20ish miles). I have experience towing our GS20 with a smaller SUV (lexus GX) and was not an issue.
i was witness to an accident caused by a trailer being towed by an undersized suv.
it was a ford explorer sport towing a rather large travel trailer.
we were on a descent on the freeway. the trailer started swaying. it progressed to the point where it caused the explorer to flip on it's side. just on it's side, no rollover.
the problem was, the driver, dad, had his window open. when the car came to a stop, dad's head was pinned at the neck between the ground and the a-pillar of the car.
with all the people on the scene, there was absolutely no way we could lift the car off the man.
had to wait until ems arrived to lift the car. to say the least, the man did not survive.
so after watching that accident and experiencing my boat control my Tundra on one occasion, it has been a rule of mine to always have a truck big enough, maybe even overkill to handle the loads i may be hauling.
