My boat sits on a Road Runner trailer. The prop guard scrapes when I back it into storage due to the ramp being to steep. Has anyone added skid wheels or a lift kit to their trailer? I was thinking of a 2 inch lift kit. What are the pros and cons to both? Any easy kits without fabricating something? Thanks for the help.
A d m i n i s t r a t o r
- Mar 2002
- 16517
- Lake Norman
- Mooresville, NC
I strongly recommend against a lift on the trailer. If you do that, it will require backing the trailer much farther into the water when you want to launch the boat. So much so that you may have to completely submerge your rear bumper, etc.
Most people just add the prop guard rollers. They usually order them and have them welded on at an auto body shop or similar place.
The third option is to get two good-size boards and put those down on the path of the tires at the storage location to lift the trailer as you back it into place.
One last thought is to get an adjustable hitch for your truck, and lower it all the way down when backing into your storage. That may lift the prop guard enough so that it doesn't scrape.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
- Jun 2008
- 2080
- Flowery Branch GA Lake Lanier
- 2008 210 SANTE 67 Correct Craft Mustang
I lifted my SMP tandem trailer on my 89 Supra Sunsport one inch. The biggest problem was loading and unloading double pitched ramps the cross bar would always get hung up. Adding wheels on the prop guard would not help. Its been 20 plus years no problems so far.
Thanks. I cannot imagine having any problems from lifting at my boat ramp. It is fairly steep and the boat floats way before I get close to the water. Researching the wheels. I can weld and fabricate something if needed. I do not have a source for them. Any ideas? Is there a weight requirement on the wheels needed?
Amazon has some, any trailer Sales or service place will sell them too.
https://www.amazon.com/Roller-Caster...8613501&sr=8-62009 Super Air Nautique 210 TE
1989 Sport Nautique
