2013 G23 Transom Straps Rubbing on NSS
  • SCNautique210SAN
    • Mar 2011
    • 194
    • SoCal
    • 13 G23 04 SAN 210TE 92 Sport Nautique
    Hey guys,
    Was wondering if anyone with the first era of G23s and Boat Mate trailers has this 'problem' or not. Essentially the transom straps are rubbing up against the NSS covers and is starting to wear the black paint & gel coat below.
    Anyone else have this problem and have found a solution?
Name:	Screen Shot 2020-07-15 at 10.26.14 AM.png
  • bturner
    • Jun 2019
    • 1576
    • MI
    • 2016 200 Sport Nautique
    I don't have your rig but I was going to have a rubbing problem on my if I mounted directly to the trailer. I bought a set of these mounting brackets to provide a stand off from the trailer.....
    https://www.etrailer.com/Accessories.../IMF14254.html
    • SCNautique210SAN
      • Mar 2011
      • 194
      • SoCal
      Thanks bturner I'll give this a go and see if/how it'll work.
      • robertsmcfarland
        • Oct 2004
        • 544
        • Hyco
        • 2014 g23 550
        I have the same set up but only trailer if I have a problem and have to take to white lake which i did last week that said ,my straps don't come close to rubbing, my boat must sit a few inches further up...can yo move your trailer winder forward few inches , that might do the trick
        2013 G23 super air
        2010 230 super air
        2009 220 super air
        2008 210 super air
        2005 210 super air
        2003 calabria pro air
        • SCNautique210SAN
          • Mar 2011
          • 194
          • SoCal
          robertsmcfarland it sits on the winch up front. Not sure how much further I could get it on the trailer if that's what you mean? Or do you mean physically removing the winch mount and welding it forward?
          • robertsmcfarland
            • Oct 2004
            • 544
            • Hyco
            • 2014 g23 550
            my trailer is put up now so I cant look but was thinking of moving whole winch mount forward but not if you have to break weld
            2013 G23 super air
            2010 230 super air
            2009 220 super air
            2008 210 super air
            2005 210 super air
            • trip33
              • Nov 2010
              • 248
              • Odessa, FL
              I do not have the same trailer, have a galvanized Continental bc we use in salt occasionally. It does not have the built in straps, but when I attach the ratchet straps up to the platform brackets they sit on the NSS covers as well so I bought some Sham-wows and cut them into smaller squares then cut a slit to run the ratchet straps through. When I tighten the straps I position the Sham-wow between the strap and the NSS covers/hull. No scratches or scuffs.
              • SCNautique210SAN
                • Mar 2011
                • 194
                • SoCal
                THanks trip33 I thought of using a microfiber to do something similar. I think I'll definitely use that approach at least until I figure out a permanent solution
