DHM Trailer, no safety chain
  • Packer Backer
    • Dec 2019
    • 7
    • Washington
    New to the family... my first boat is a 08 SANTE 210 w/DHM trailer. There is no safety chain. What is everyone running or do you recommend. I am going to be trailering this thing all over this summer and want to make sure I’m safe.
    thanks for any input.
    Click image for larger version  Name:	532E776B-8482-4B25-946E-19284FD226AC.jpeg Views:	41 Size:	116.6 KB ID:	636514
  • Lakejackson
    • May 2012
    • 160
    • Lake
    • 2011 Sport 200
    Are u asking about a safety chain to secure bow to trailer? If so a turnbuckle works well. Closeup pick of ur setup would be helpful
    • Packer Backer
      • Dec 2019
      • 7
      • Washington
      Yes, bow to trailer. Here are a few more Picts...
      Click image for larger version  Name:	0A9B13F6-076F-41C3-B768-D476FDCD48C2.jpeg Views:	175 Size:	99.1 KB ID:	636530
      Click image for larger version  Name:	8100CA1C-0528-4D6D-8398-A89381D68564.jpeg Views:	185 Size:	117.2 KB ID:	636529
      • bird_dog0347
        • Oct 2020
        • 347
        • DFW
        • 2021 G23 Paragon
        Are you asking about replacing the safety cables with chains that are already on there? I've got a triple axle boatmate for my new P23 and it has safety cables like that.
        • Packer Backer
          • Dec 2019
          • 7
          • Washington
          No, just a safety chain/cable from bow to trailer.
          • Rogue14
            • May 2010
            • 48
            • Southern Oregon
            • 2007 SV-211
            My SB Trailer for my 2007 SV211 also came with no safety chain (or spare tire). I had a guy attach one and it was done by attaching the chain to the bolt holding the winch to the trailer. From your pics, I'm not sure that would work for you but I'm sure something could be done. I agree that relying on the winch strap alone is not a good idea.
            • bturner
              • Jun 2019
              • 1571
              • MI
              • 2016 200 Sport Nautique
              I'd run one and actually just installed a boat buckle brand one on my boat trailer yesterday. You have a bunch of options to rig one up depending on how much you want to spend, how much trouble you willing to go to and how you want it to look/function.
              The most expensive, time consuming and probably best way would be to have a slotted bracket welded to the trailer frame directly below the bow eye when the boat is sitting on the trailer which is how they do it on new trailers. You'd install a retractable strap and you'd have a DFL ("D' F'ing Lux") set up. For this installation, if you don't know how to weld or have a welder you're taking it to a shop to have it welded then painting the area after it's been welded. The painting part isn't as hard as it may sound due to the location and you have a black trailer.
              Next would be to drill a hole through either the tubing in the location described above and use a stainless steel eye bolted through the tubing or you could to the same thing at the winch tower post.
              I have seen people get a grade 8 bolt and replace one of the winch mounting bolts closest to the bow eye, then run some stainless chain with a hook on the end.
              Lastly there's the, just get a ratchet strap and find a place that looks like it'll hold it. Probably somewhere on the winch tower.
              All the listed options I would say are better than nothing.....
              • jhiestand
                • 778
                • Columbus, Ohio
                • 08 Super Air 210
                Easiest thing would probably be to just get a bow tie down such as this. From the looks of your setup should be plug-n-go. Saw this one at Cabela's.
                '08 Super Air Nautique 210
                • Packer Backer
                  • Dec 2019
                  • 7
                  • Washington
                  Thanks for all the feedback. Was even thinking about a retractable strap.
                  but then started to question the strength of strap vs chain...
                  • Packer Backer
                    • Dec 2019
                    • 7
                    • Washington
                    This looks like a strong option:
                    https://www.pacifictrailers.com/prod...AaAkDjEALw_wcB
                    • shag
                      • 2217
                      I think that cable from Pacific trailers would work fine. Be sure it is mounted with a grade 8 bolt. Stainless would be nice but not as strong.
