Anybody know what current Fulton jack will retrofit to the 2008 Eagle Trailers
  • swatguy
    • 1631
    • Midwest/ Northern IL
    • 2008 SANTE 210
    My jack has finally seen better days . Looking for a replacement. Seems like every jack I look at has a different mounting plate. Anybody know what direct mounts to my Eagle or have ideas ???
  • XBIGPUN66
    • Oct 2012
    • 456
    • WI
    I think I bought that jack either from nautiqueparts.com or from a trailer website for my old trailer. Then you bolt it right on the welded plate
    Ian S
    • ScooterMcgavin
      • 1478
      • 2014 SAN 210 TE
      this one looks real similar
      https://www.etrailer.com/Trailer-Jac...on/FXP15W.html
      1989 Sport Nautique
      • MN Ryan
        • Aug 2020
        • 1250
        • Maple Grove, MN
        • 2007 SV-211 TE
        I have an '07 Eagle that looks about the same as yours. The PO just pulled that one off and u-bolted a Fulton F2 on the other side. Works for me.
        • swatguy
          • 1631
          • 2008 SANTE 210
          Thanks for the replies all. Scooter , that looks like the match.
          Ryan
          never thought about swapping sides that would eliminate the clearance issue.
          • bturner
            • Jun 2019
            • 1572
            • MI
            • 2016 200 Sport Nautique
            If you're looking to go F2 I think we were making an adapter plate for those but you still need the 4 holes in the bracket. The one I did like this when we tested this years ago had the center bolt but still had the 4 holes behind the plate. I used a cut off wheel to remove the center bolt but you could do this with a hack saw as well. See if you can see behind the plate and look for the holes. If you're interested going this direction you can see the adapter plate here...
            http://liquidcut.com/tools.aspx
            These are the same ones we've been offering on TT for years. I think we made about 80 of these over the years and can adjust the hole pattern as need.
            Or if you're good with replace this jack with the original style..... Never mind.
