Anyone know how much the plastic version on the Ramlin bow stops are?. My carpeted version are starting to rip and I thought about replacing it with the newer style.Thanks
Tags: None
RE: Trailer Bow stops.
Good question. Is there anyhting out there that you could make your own out of? (Say from Lowe's or Home Depot?) Come on, Some of you guys in construction should know :!:Tomfooter
\"You could by a cheaper boat, but then you would have to ride it.\"
I have the plastic ones, but wish I had the carpet back. The rub the rub rail as sell as the cover. I would stick with carpet.
Re: RE: Trailer Bow stops.
Originally posted by cradsv21104The rub the rub rail as sell as the cover.1990 Ski Nautique
NWCT
RE: replace them
Make sure if you get HDPE (high density ployethylene) you get the UV resistant. You can get it from McMaster Carr, but there it is not cheap. There are other sources.
RE: replace them
I replaced my carpeted ones with the plastic. Purchased from White Lake Marine last year. As I recall the cost was around $65 for the pair.88 Barefoot Nautique
05 206 Team
RE: replace them
Man the English in my post was LOUSY...sorry guys.
